[SOLVED] Audio problem
Feb 5, 2020
HELP ...
My PC can't find my speakers and headphones when they are plugged in. Is there any solution?
There's a red X on the audio icon.
My PC didn't recognize any audio dispositive, speaker, headphones or audio recording device.
I couldn't turn up, down or mute the volume with the shortcust and same with the volume icon, when i right click it, it just opens the error fix thing but doesn't detect anything wrong.
D
run the Troubleshooter. Does it fix anything? you can use the DDU utility from Save Mode to uninstall all audio drivers, then get the latest ones and try that. if that don't work, a clean install of the OS should work. and if that fails, your sound electronics on the mobo are actually bad
