[SOLVED] Audio skipping about every 5 seconds ?
17
This problem didn't used to happen, but recently my audio regularily cuts out and cuts back on about every 5 seconds. I've tested it with my 3rd party audio applications turned off, and with multiple audio outputs, and no luck, so any help is appreciated.
Operating System
Windows 11 Home 64-bit
CPU
Intel Core i5 @ 2.90GHz 74 °F
Comet Lake 14nm Technology
RAM
32.0GB Dual-Channel DDR4 @ 1329MHz (19-19-19-43)
Motherboard
LENOVO 3730 (U3E1) 92 °F
Graphics
C24F390 (1920x1080@60Hz)
Intel UHD Graphics 630 (Lenovo)
8192MB ATI Radeon RX 580 Series (C.P. Technology) 65 °F
CrossFire Disabled
Storage
476GB SAMSUNG MZVLB512HBJQ-000L7 (Unknown (SSD))
Optical Drives
No optical disk drives detected
Audio
VB-Audio Virtual Cable
My computer is regularly freezing. While haven't noticed it happening at any specific time, it doesn't seem to happen when I am signed out, and typically happens when applications are running (e.x. Google Chrome, Discord, etc). I've tried all of the fixes at this link and nothing has worked so far:
Operating System
CPU
RAM
Motherboard
Graphics
CrossFire Disabled
Storage
Optical Drives
Audio
You could've listed the specs to your build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. BIOS version for your motherboard at this moment of time.
if this system is a Lenovo prebuilt, then you could simply add an SKU for your system.
Do you have any updates pending on your OS? Speaking of OS, did the OS come installed with your platform? You could try and uninstall the audio drivers, then manually reinstall the latest driver listed on Lenovo's support site, in an elevated command, i.e, Right click installer>Run as Administrator.
