B ios Fan Speed adjustments RS480M2
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.msi-microstar (More info?)
In the bios for this mainboard there is a 3pt. fan speed adjustment.
I've tried changing the settings and did not see any changes to the fan
speed. They are setup to allow the specified fan speed to click in at
different temperature points. The fans speed level seems to be specified
in hex. Does anybody know how to set these and what would be recommended?
Mirko
Just a viewpoint. :)
Q: What do you find annoying about the internet?
A: bottom posting.
>A: bottom posting.
Q: why is that?
>>A: bottom posting.
>Q: why is that?
A: because I do not have 10 second memory.
A: because I hate scrolling.
A: because DejaVu makes me uncomfortable.
On Mon, 04 Apr 2005 20:17:01 GMT, Mirko Hrovat <mhrovat@email.com>
isn't it voltage levels ?
There is a thread from 19-03-2005 discussing it. It seams that some
knowledge of hex is required (the comment of mcn that he doubled the
low fan voltage, wonder how he got these values in, maybe by a load
defaults).
I saw Q&C work by just setting the three temperatures. Since my cpu
temp is measured 3 degrees lower than system, I set all of them very
low.
Actually my 2 fans stop completely. Since I didn't like that, I
switched Q&C off again.
best regards
John
There are 3 fan speed , and 3 voltage settings.
Load "Optimized Defaults" and it will set it, with Cool & Quiet.
"JK" <johnknuhtsenSP@Mmail.dk> wrote in message
news:u63a51h4ia64pccb70ae44kfu98coc64s6@4ax.com...
> defaults).
> low.
> best regards
> John
