Question b1initializelibrary failed 0xc0000001. PLEASE HELP
Oct 6, 2022
lenovo legion t5 AMR26
pc won’t boot after power surge
i keep getting the same error code, i have tried to do a factor reset and everything but no luck
Update your post to include full system hardware specs and OS information.
Include PSU: make, model, wattage, age, condition (original to build, new, refurbished, used)?
Disk drive(s): make, model, capacity, how full?
Will the system boot into Safe Mode?
Any beeps? Some pattern of long and short beeps. Listen carefully.
FYI:
https://thegeekpage.com/how-to-fix-windows-10-error-code-0xc0000001/
Avoid third party tools, utilities, apps, etc. claiming to fix the problem. Some of those tools may show up no matter what problem or problems are happening.
More information needs to be learned.
thats a BIOS error.
The BlInitializeLibrary failed 0xc00000bb error is usually related to your computer's motherboard BIOS. This likely occurs if the motherboard reset to its default values. Modifying BIOS/CMOS incorrectly might cause serious issues on your computer. In line with the error that you're getting, we suggest contacting your device manufacturer for better assistance. They will be able to check what causes the issue and can help you modify and reset BIOS.
https://answers.microsoft.com/en-us...on-black/a8889e67-300c-491a-965a-df087ab5cbe1
try resetting the BIOS. An update might help as well.
I don't know how user is meant to do the work around unless its for devs: https://learn.microsoft.com/en-us/t...failed-start-os-on-64-bit-uefi-based-computer
