Question B250 Motherboard 1 Bent Pin Pls Help!
Mar 16, 2019
17
Hey guys,
I bought a used motheboard and when I get my hands on it, I have seen that there is a bent pin on it. It is just one pin but I am not sure If I need to try to put it back on place or should I just put the cpu in it and hope that it works. You may also see it on the photo's. Please tell me what I need to do.
Thanks in advance
Hey guys,
Thanks in advance
It'd help if you could post a link to the image of the bent pin on the CPU socket. Ideally you could re-bend it back into place with a pair of helping hands and a fine tweezer/screwdriver and a steady hand + credit card.
