B360 Motherboards with more than 1 RGB/LED Header
Hello,
If you don't already know you can get something like a Cooler Master 1-to-3 RGB Splitter Cable to make more of that single rgb header. if you are worried that drawing too much power through the motherboard is not a good idea then you can get something like a SilverStone Technology RGB LED 8 Port Hub which connects to a sata power connector or directly to your (modular) power supply.
