[SOLVED] B450 Motherboard and Daisy Chain 4 monitors?
Oct 27, 2021
5
Hey Everyone,
INTRO:
I was thinking of building a 4 monitor PC with onboard graphics and NO dedicated graphics card. Maybe even in a small form factor case (https://www.newegg.ca/p/N82E16811108485).
Therefore, looking at mini ITX boards with DisplayPort...
DisplayPort supports daisy-chaining monitors from version 1.2, however, there are limitations for resolution, refresh rate and the amount of displays.
Multi-Stream Transport (MST) enables "up to four WQXGA (2560 × 1600) displays at 60 Hz with 24 bit/px RGB color" (https://en.wikipedia.org/wiki/DisplayPort).
QUESTION:
https://www.amazon.ca/MSI-Performance-Display-Mini-ITX-Motherboard/dp/B08LMVRZ73/
... is quite a nice buget board and it does have a DisplayPort, but the specs don't tell which version.
Does anyone have experience with this board, or a suggestion which other board to use that can daisy-chain 4 monitors?
best regards
K
Okay,
so an AMD Ryzen 3200G, for example, should support HBR3, therefore DP1.3
Some motherboards specify the display port (i have seen 1.2)
Does this mean it will only support 1.2, or is the displayport functionality entirely determined by the APU?
hehe, since i want to cheap out on most of the setup, i totally get their point.
thank you for your replies :)
DP1.2 should still be fine for 4 monitors 1920x1080 at 60hz (https://www.tripplite.com/products/multi-stream-transport-mst-hub-technology)
They do it with a hub on that page, but it should work with a daisy-chain, too, right?
If i want one main display to have a higher resolution, i could still connect it to the HDMI out.
Although, i am not sure that the apu runs the HDMI and 3 daisy-chained monitors on the DP1.2
SETUP:
Case: https://www.newegg.ca/p/14G-0047-00002
CPU: https://www.newegg.com/amd-ryzen-3-3200g/p/N82E16819113571
CPU cooler: https://www.amazon.ca/Noctua-NH-L12S-low-profile-cooler-quiet/dp/B075SF5QQ8/
Motherboard: https://www.newegg.ca/gigabyte-b450-i-aorus-pro-wifi/p/N82E16813145086
RAM: https://www.amazon.ca/Corsair-Vengeance-PC4-28800-Desktop-Memory/dp/B07RM39V5F/
SSD: https://www.newegg.com/crucial-500gb-p2/p/N82E16820156245
4xMonitor: https://www.newegg.com/crucial-500gb-p2/p/N82E16820156245
APPROX 1150 USD
