Question B550 tomahawk with ryzen 5 5600x - BIOS flash via USB not working
Nov 9, 2020
I have just changed my motherboard to a MSI b550 tomahawk with a new cpu ryzen 5 5600x, its constantly stuck with the EZ debug cpu led on when starting with no display detected at all. I've tried 3 different usbs with the bios update file from MSI's website and everytime it will start to flash a few times when pressing the bios flash button on the back, the pc will start itself and the fans will start spinning but the bios led will just continue to flash and not stop at all. I have waited for an hour previously to see if it would work but it just keeps flashing. Is there any solutions anyone may have? Would be greatly appreciated.
Are you trying to bios flash with the CPU installed into the motherboard?
I believe the USB bios function is intended to work without the cpu installed.....
I found a vid about how to do this (as there aren't any instructions I could find quickly on the MSI website):
View: https://www.youtube.com/watch?v=rTBs0-gTJRI
Note that there are some specific requirements on the formatting of the flash drive and such, hopefully that helps.
I have tried and followed the method in the video and it still just flashes constantly, it never goes to a solid light or goes off... I'm so confused as to why it looks like it's working and just never stops blinking.
Have you tried a different bios version (if there are any others available that support the 5000 series cpu?)
Edit, looking on the MSI site, there appears to be 2 versions of Bios that should support the 5600X... version 7391vA3 and 7381vA4.... whilst the latter is the optimal version for the cpu, the older one includes AGESA 1.0.8.1 which does include Ryzen 5000 cpu support. Might be worth trying that to see if you can get the system started. Once it's running you can then update to the newer version from within the bios itself.
I have tried various Updates from MSI'S page ranging from latest to oldest, it still has the same issue. I have tried 3 different usb drives as I've seen that as a viable solution but it has not been for me.
hi i have almost same issue with b550 but uu can try diffirent usb stick ihad same problem and chnaged to other usb stick format it to fat32 and rename bios file to msi.rom copy and if led blink only few sec some is wrong repeat i had same problem for like 10 times chnaged 2 usb stick and 3rd worked asap , process is like 5 min max and when stop blinking is over is auto restarts shut down pc , install cpu and done
Hope this helps someone
Reactions: drea.drechsler
This is mentioned in your mobo manual -
Updating BIOS with Flash BIOS Button
  1. Please download the latest BIOS file that matches your motherboard model from the MSI® website.
  2. Rename the BIOS file to MSI.ROM, and save it to the root of your USB flash drive.
  3. Connect the power supply to CPU_PWR1 and ATX_PWR1. (No need to install CPU and memory.)
  4. Plug the USB flash drive that contains the MSI.ROM file into the Flash BIOS Port on the rear I/O panel.
  5. Press the Flash BIOS Button to flash BIOS, and the LED starts flashing. 6. The LED will be turned off when the process is completed.
I'm fully aware of this. I've done all the above on multiple USB's now and it doesn't stop flashing
Hello,
I have the same issue, did any of you guys find solution? I bought new msi mag b550 tomahawk with ryzen 5 5600x. And tried with bios update many times, and send cpu to service they said it works fine. Checked also psu wich is also brand new on my old motherboard it works fine...
