Backlight problem Samsung syncmaster p2250
Doronz
5
My screen turns on for about a second, and then turns itself back off.
I've used a flashlight on it, and I could still make out the window shapes, so I gathered that it is a backlight problem.
I've opened it up, looked at the board, and all the capacitors appear to be ok (flat at the top).
I've read that I might need to replace the inverter board, but I couldn't really figure out what that is.
I'd really appreciate any help at this point.
edited to add photo.
I had a same problem and a found that it was problem wiht the resistor on exit to the lams. I see that you have one resistor. In my boar was on the back side 4x56kohm an i put there one 220k ohm. Now it works fine. In your foto it is the top left one with red-red-yellow-gold colors
I had the same problem as you, also replaced the 4 56K resistors. They lasted a few minutes and burned out again.
I'm also looking for answers at this point. I found the service manual. It says sweet nothing about inverter problems, nor does it give schematics.
Reactions: Bighouse
Huge kick, but did you succeed in the end? I'm having the same problem, where a 220K ohm 0.5 watt carbon film resistor burnt out. But maybe I need a more serious 5W resistor, or something.
