Jan 25, 2025
I’d like to know if any of these components could cause problems in high-end gaming on my 1440p 240hz ultra wide monitor.
Asus proart OC RTX 4080 super
AMD Ryzen 7 7800X3D
ASRock PG riptide b650 mATX Mobo
G.Skill trident Z5 Neo 32 GB DDR5 RAM
970 Evo plus 2TB
Cooler master hyper 212 halo cpu cooler
4 case fans (3 front intake, 1 rear exhaust)
Corsair RM850e PSU (860 watts, 80+ Gold)
AMD Ryzen 7 7800X3D
970 Evo plus 2TB
Yea, it’s pretty balanced.
Great build! Phenomenal (build approved)
On paper, it's good but I'd ditch that rubbish cooler for something better, like a Thermalright Peerless Assassin 120SE. You forgot to mention the make and model of your case.
Got a link to the ram kit you've listed up there?
On second thoughts, you're advised to stylize your thread like so;
inclusive of where you're located, what your budget for the build is and your preferred site for purchase. Brand and parts availability can and will change due to region.
PCPartPicker also helps keep things concise with parts listening and fleshing potential compatibility/clearance issues.
AMD Ryzen 7 7800X3D
970 Evo plus 2TB
The Hyper 212 is OK. Maybe look at this article and see if you can improve your cooling -- https://www.tomshardware.com/reviews/best-cpu-coolers,4181.html#section-best-air-coolers
