Barton temp. issue
cera26
14
I recently purchased a barton 2500+ and I am using the stock cooler with it. My mobo is MSI k7n delta nForce2. The reason I am concerned is that, during tasks such as surfing and writing e-mail, PCAlert reports a CPU temp. of 58 C. Is this normal? I remember reading somewhere that the temp. shouldn't exceed 50 C under load. Thanks for your help!
Death to all trolls (Intel trolls, that is. AMD trolls aren't really trolls :)
58 is kinda warm whats the ambient room temp like.
You may wish to try some Artic Silver or other quality thermal compound.
and or a better HSF
as well as seeing if you can increase airflow in the case.
<begin> clever sig </end>
Do not use Arctic Silver, you will void your warranty, are you sure when you installed the heatsink, it had a thermal pad? You definently need to reinstall the heatsink, you didn't install properly, I doubt if it's making proper contact with CPU core.
<A HREF="http://forums.extremeoverclocking.com/myrig.php?do=view&id=17301" target="_new">My PC</A>
Go to the MSI forum on MicroStar's web-site. You can't trust any temps you get off of that board.
"I am become death, the destroyer of worlds. Now, let's eat!
