R riwagodfrey Distinguished May 11, 2011 2 0 18,510 May 11, 2011 #1 my laptop hp pavillon 6500 entertainment pc is missing base system device after i have installed window 7
hang-the-9 Titan Mar 25, 2010 60,372 1,078 152,940 May 11, 2011 #3 Don't post duplicates, check the other forum you posted in. Upvote 0 Downvote
wanamingo Distinguished Jan 21, 2011 2,984 1 20,810 May 11, 2011 #4 ftp://ftp.hp.com/pub/softpaq/sp37501-38000/sp37614.exe tada!! Upvote 0 Downvote
D devrathiya Distinguished May 12, 2011 15 0 18,520 May 12, 2011 #5 Hi, Base system device bang in device manager indicates that it is missing the chipset drivers. Try inserting the drivers disc that you received with the system and installing the chip set drivers and that takes care of it. Cheers Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,738 1,824 159,590 May 12, 2011 #6 your likely missing the intel chipset drivers! http://www.intel.com/products/chipsets/index.htm Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,738 1,824 159,590 May 12, 2011 #7 http://www8.hp.com/us/en/support-drivers.html search here! Upvote 0 Downvote
