Hello all,
I am new to AIOs and watercooling in general. I am thinking of changing my current CPU air cooler for an AIO and I have some questions.
Firstly, which way should my radiator fans blow? The case I will probably be using will be a Meshify S2 and I will probably mount the radiator up top. I will have three 140mm fans in front, one at the rear, and so that leaves the fans in the radiator.
Secondly, which one should I go for? I am currently looking at the H150i Pro, but would welcome other suggestions. Would going for one with two fans be better for my overall fan setup? I’m worried multiple fans at the top may disrupt airflow.
Thirdly, should I replace the stock fans that come with the AIO I choose? I’ve heard the stock fans on the H150i Pro aren’t that good so I was thinking about getting some Noctua NF-A14s to replace them.
Thanks! Answers to any or all of my questions are much appreciated!
