Basic query about a Labtec optical wireless mouse
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
I have a Dell Dim 2400 system with XP Home. I got this mouse as a present. I
like it; it works very nicely.
My question concerns the battery usage. It comes with 2 AAA batteries.
The documents say it will last 2-3 months. They also say to extend battery
life, remove receiver (from USB port) and snap in back of mouse (when I do
that it shuts off the mouse). That is a PAIN to do. I may do it, however.
I gather otherwise the mouse is always on? (My computer is on all day every
day). I assume the batteries are being used even when you are not using the
computer?? Is that true?
So, how long should I really expect the batteries to last if I don't remove
the receiver every time I leave the computer??
Also, the documentation doesn't say anything about using rechargeable
batteries. Can you?? If so, Can I use the NiMh ones?
Mel
----- Original Message -----
To: Mel Billik
Sent: Tuesday, February 15, 2005 10:47 AM
Subject: Re: mouse
Get rechargeable batteries, normal batteries will probably run two weeks
the way you use it. On way back, should get home the evening of the 17th.
Larry
Mel Billik <mbillik@charter.net> wrote:
Cheryl gave me an optical mouse as a Valentine's Day present. It's a
labtek one and it works VERY nicely. It seems to respond much quicker than
my other mouse. Not sure of how long the batteries will last. It takes 2 AAA
batteries.
Mel
No virus found in this outgoing message.
Checked by AVG Anti-Virus.
Version: 7.0.300 / Virus Database: 265.8.7 - Release Date: 2/10/2005
Do you Yahoo!?
All your favorites on one personal page - Try My Yahoo!
No virus found in this incoming message.
MB_ ,
Consider purchasing a set of four (4) AAA rechargeable batteries, and
recharger. My Logitech wireless optical mouse usually last about 5 days
before I get the warning, that the batteries are getting low.
Rich/rerat
(RRR News) <message rule>
<<Previous Text Snipped to Save Bandwidth When Appropriate>>
"MB_" <mel@prodigy.invalid.net> wrote in message
news:5RpQd.10341$KZ2.3716@fe06.lga...
Mel
To: Mel Billik
Subject: Re: mouse
Larry
batteries.
Mel
Do you Yahoo!?
Rich:
So, can I assume the device will take those kind of batteries (I might just
email labtec and ask them)
Mel
"RRR_News" <nospam@isp.com> wrote in message
news:VaCdnRDtAeZk0o_fRVn-qA@comcast.com...
> MB_ ,
> Rich/rerat
> I
> every
> the
> remove
> Mel
> From: Lawrence Thompson
> To: Mel Billik
> Subject: Re: mouse
> Larry
> AAA
> batteries.
> Mel
> Do you Yahoo!?
Yes it will take the NiMh batteries. I am using Rayovac NiMh batteries in my
mouse. You can also use alkaline batteries that have been recharged, if the
recharger is capable in handling them. Just check for leakage during/after
the recharging process.
Add MS to your News Reader: news://msnews.microsoft.com
Rich/rerat
news:tpsQd.10519$eB4.3455@fe06.lga...
Rich:
Mel
> MB_ ,
> Rich/rerat
> I
> every
> the
> remove
> Mel
> To: Mel Billik
> Subject: Re: mouse
> Larry
> AAA
> batteries.
> Mel
> Do you Yahoo!?
