I plan to build a new gaming PC. I used PCPartPicker.com to select the parts and peripherals for the PC. In addition, I intend to hook up a battery backup unit to the PC. PCPartPicker estimated my wattage for my PC build to be 651 watts. The power supply unit I intend to use inside the PC is rated at 1000 watts 80 Plus Gold and the battery backup system I am considering is also rated at 1000 watts. In addition to the PC, I plan to connect my monitor, 2.1 speaker system, and external hard drive to the backup system. These parts are also on my PCPartPicker list. Based on my research, it appeared that it would be best to go with a 1000 watt backup battery unit both to give me sufficient time to shut down my PC during a power outage and to give me some wiggle room in case I purchase an upgraded or additional PC component in the future that increases the power consumption (similar reasoning with the PSU).
This is the backup system that I am considering: https://www.amazon.com/dp/B00429N19W?tag=pcpapi-20&linkCode=ogi&th=1
I am no expert on battery backup systems, so I am asking if this backup system will work for my gaming PC or if you believe that there are better reliable alternatives.
Thanks.
Thanks.
