Battey not detected after fan cleaning
Milad_6
Hey everyone,
Sitrep:
- opened the laptop and unplugged the battery
- cleaned the fan and ...
- plugged the battery again
- error comes up saying the battery is not detected / not charging / unknown remaining
system:
- dell vostro 5470
[Update 5/17/2017]
Got it checked by a local laptop technician:
- motherboard and all components: OK
- battery connector male/female: OK
- battery positive/negative wires: OK
- battery data/clock/thermistor wires: Unknown
- battery cells: OK
- battery controller board: Unknown
- battery voltage and current: OK
- battery charge/discharge: OK
- battery even works for 5 hrs under high usage
Milad_6
Please read the update. I dont hope for a miracle here. I'm merely looking for a hint; sometimes a simple overlooked idea is all we need. Thanks anyway.
So the battery actually works for hours like it is seen normally? And charges OK? Maybe one of the connectors got damaged, that update shows the data wires are "unknown" which is exactly what would be sending the signals to the computer from the battery about it's status.
Milad_6
Yeah, everything looks normal, yet the system does not detect any battery! The wires are probably fine. My guess is the cell experienced a kind of shock when removed from the motherboard and so the battery controller board somehow got damaged/mixed up.
