can anyone point me in a direction. Im apparently stuck in the first level, cant seem to open the door on the train. I get prompted to do nothing?
Am i missing something? this shouldnt be hard!
This doesn't sound like a graphics card error but I will give you both diagnostics.
Depending on both your system and your drivers it could be either one.
If you know your system is more than minimum requirements (I'd say Within past 3-4 Generations on hardware) you should be fine on that.
If you have newer graphics card say the 6k (6,000) / 5k series try updating drivers to the 11.10 Preview 3 drivers. http://support.amd.com/us/kbarticles/Pages/GPU124AMDCat1110PreDriverV3.aspx
Those fixed most everything for me.
Other diagnostic:
The install might have corrupted, if so a clean reinstall would clean it.
thanks it runs well..seems though its a bit of an overkill though 🙁
just this game (bf 3) doesnt seem to run right...let me rephrase that.. like when "cutting the red wife" he doesnt do anything after I follow it as he is supposed to??
do you know?
by shutdown I mean it shut itself down all the way and rebooted back up again??
I guess it is rebooting not shutting down.
Do you get any BSODs ? it sounds like a hardware component is overheating or overloaded such as the PSU, but 1200W is pretty sufficient for such a rig.
Did you check your GPUs temps, it's pretty much the cause...the HD 6990s are known for overheating as they are reference designed cards
