Question BDOS after fresh install, help please!
Jan 26, 2021
64
I just did a completely fresh install after wiping my drive. I've only installed two drivers, one at a time, the first razer synapse and I waited and no crash then I installed nvidia gpu driver, bsod almost instantly. Rolled back the drivers and now its constantly crashing. I recently ran memtest86 for 8 or so passes with no errors on my memory. If anyone can help, it would be greatly appreciated!
I linked the dump files below along with msinfo.
https://drive.google.com/drive/folders/1ugYq3svdpjOmLtX5rcu6Jg1GmZngvRNW?usp=sharin
Windows Performance Analyzer doesn't even seem to be part of windows, I can find it on the store so it is from Microsoft but not why its making a 50gb file - https://www.microsoft.com/en-au/p/w...activetab=pivot:regionofsystemrequirementstab
WPR - Windows Performance Recorder
WPA is used to read WPR files.
since you have the file, you could always look to see whats in it - https://docs.microsoft.com/en-us/windows-hardware/test/wpt/wpa-step-by-step-guide
it might tell you what is wrong as PC is trying to figure it out itself.
that error code seems to have many answers. Could be hardware, could be drivers, could be a corrupted registry.
I doubt it will make any difference but you can try updating Win 10, you on 20H1, current version is 20H2
Sorry for the delay, there were some issues that came up. The only solution I've found is using DDU and uninstalling the Nvidia drivers, but no matter what driver I replace it with it will BSOD like before. Any suggestions?
You don't have to explain why you don't answer, I would be here anyway... its your thread, answer when you want to.
what are specs of the PC?
Have you tried GPU in another PC to see if it has same problems, as it might be the card itself
AMD Ryzen 7 3800x
16GB DDR4 3000mhz
1.5TB NVMe WD black
EVGA GTX 1070
Thermaltake 850 gold+
And yes, I also have a 970 I was using just before moving to the 1070. I swapped it out and did the same thing and it still blue screened.
was that only change?
Oh no, my old system has been completely replaced. I used to run a FX-8350, sabertooth mobo, ddr3 and single evo pro ssd. That with the 970, then I upgraded everything around december and had issues from the start. But at some point they just dissapeared, no bosd, no unexpected shutdowns nothing. Then about 2 or 3 weeks ago it started again and here we are.
so its really just a constant and everything else changed around it.
So everything in new system is new.
so i was about to suggest memtest but you done that. I have seen ram be the cause of constant BSOD blaming gpu, one user even swapped from AMD to Nvidia and errors just swapped from AMD display drivers to Nvidia.
CMK16GX4M2D3600C18 why aren't you running it in DOCP?
MSI never tested this ram with motherboard
Corsair tested the ram with motherboard, so it should work.
Not sure why its blaming Nvidia on 2 cards. I don't believe it.
Try running Prime95 - - https://www.mersenne.org/download/
Prime 95 Guide: http://www.playtool.com/pages/prime95/prime95.html
it tests CPU & Ram.
I was finally able to run a verifier without it getting corrupted. Below is the bsod from it. I think its wifi drivers, but I'm not 100%
https://drive.google.com/drive/folders/1ugYq3svdpjOmLtX5rcu6Jg1GmZngvRNW?usp=sharing
I ran the dump file through the debugger and got the following information: https://jsfiddle.net/290wnbtd/show This link is for anyone wanting to help. You do not have to view it. It is safe to "run the fiddle" as the page asks.
File information:020321-4453-01.dmp (Feb 3 2021 - 15:06:20)
Bugcheck:DRIVER_VERIFIER_DETECTED_VIOLATION (C4)
Probably caused by:memory_corruption (Process: svchost.exe)
Uptime:0 Day(s), 0 Hour(s), 00 Min(s), and 16 Sec(s)
This information can be used by others to help you. Someone else will post with more information. Please wait for additional answers. Good luck.
it doesn't show a name but it shows clues.
ndis.sys was involved. Its the network Driver Interface Specification so its leading me to look at your network drivers...
also mentions NETIO.sys which is also the driver windows uses to talk to network.
Sep 03 2018Netwtw04.sysIntel Wireless Wifi Link driver https://downloadcenter.intel.com/
Jul 10 2020ibtusb.sysIntel(R) Wireless Bluetooth(R) Filter driver (Intel Corporation)
Jan 04 2021rt640x64.sysRealtek NICDRV 8169 PCIe GBE Family Controller driver https://www.realtek.com/en/
Ethernet looks new, WIFI might need an update?
bios is not reporting to the system what your specs are, Are you on newest bios?
I am on the newest stable BIOS and newest chipset. One question could Overlap: Directories cause BSOD?
i never read those logs - it seems some of those are normal - https://www.tenforums.com/general-s...erlap-directory-recorded-my-cbs-log-file.html
and no, i don't think so. BSOD normally caused by drivers or physical problems. There are some bsod that are windows files but they could be caused by physical problems as well. Shared folders likely at most cause an error if both users tried to access at once, but not cause PC to crash.
Hmm, ok that makes sense. But I don't have any shared folders enabled. Also, this is the log from when I ran DISM and there's a lot of fails in it, but I don't know if these are normal ones.
https://drive.google.com/drive/folders/1-SgbWxS5rbNcn_YJLWJMFTZNMIF4GLCd?usp=sharing
there are some errors there, what did it show at end?
can you right click start
choose run...
type winver and press enter
current version is 20H2, I think you on 20H1 (might say 2004)
OS Build 19042.746 is latest.
to fix DISM if it does indeed still have problems, requires a copy of the iso for the version of win 10 currently installed. I doubt you have that. And newest ISO is for 20H2.
you might want to click the 1st link on this page, download the upgrade assistant and upgrade to 20H2. It might fix DISM along way as it should replace it. https://www.microsoft.com/en-au/software-download/windows10
choose run...
I have the ISO all the back to 1507. With what I have right now I'm not getting any BSOD just yet because of it, but it did BSOD when I try to install Discord.
is the iso on USB or hdd?
mount that ISO in file explorer (see Here) and then copy paste the below command into command prompt (admin)
spacing is important, if its not exact you will get error 50
DISM /Online /Cleanup-Image /RestoreHealth /source:WIM:X:\Sources\Install.wim:1 /LimitAccess
Where "X" is the drive letter where the ISO is located. Simply change the "X" to the correct drive letter
that fixes dism
