Question BDOS after fresh install, help please!
Jan 26, 2021
64
I just did a completely fresh install after wiping my drive. I've only installed two drivers, one at a time, the first razer synapse and I waited and no crash then I installed nvidia gpu driver, bsod almost instantly. Rolled back the drivers and now its constantly crashing. I recently ran memtest86 for 8 or so passes with no errors on my memory. If anyone can help, it would be greatly appreciated!
I linked the dump files below along with msinfo.
https://drive.google.com/drive/folders/1ugYq3svdpjOmLtX5rcu6Jg1GmZngvRNW?usp=sharin
is the iso on USB or hdd?
mount that ISO in file explorer (see Here) and then copy paste the below command into command prompt (admin)
spacing is important, if its not exact you will get error 50
DISM /Online /Cleanup-Image /RestoreHealth /source:WIM:X:\Sources\Install.wim:1 /LimitAccess
Where "X" is the drive letter where the ISO is located. Simply change the "X" to the correct drive letter
that fixes dism
Its on a USB
its almost 11am, so I guess you could call that late :)
Hahaha, late for me I suppose. One last thing, can this cause a BSOD if you know off the top of your head?
Catalog Database (2292,D,12) Catalog Database: The database format feature version 9080 (0x2378) could not be used due to the current database format 1568.20.0, controlled by the parameter 0x410022D8 (8920 | JET_efvAllowHigherPersistedFormat).
Its the one error thats constant with every BSOD ive had
database error, almost everyone gets esent errors.
No, should not cause BSOD. You sure are looking though. Not often you find answer to BSOD in event viewer. There really isn't anywhere that shows you in windows. i mean, the dumps do but they aren't easy to understand even after conversion.
if they were easy we wouldn't be on page 3,
its late for me, i been awake all night answering questions :)
Yeah looking for sure this has been happening for a month and its my gaming rig. And DCom Errors are common too arent they?
I ran the dump files through the debugger and got the following information: https://jsfiddle.net/3j4behqk/show This link is for anyone wanting to help. You do not have to view it. It is safe to "run the fiddle" as the page asks.
File information:020421-7734-01.dmp (Feb 4 2021 - 18:33:45)
Bugcheck:PAGE_FAULT_IN_NONPAGED_AREA (50)
Probably caused by:memory_corruption (Process: explorer.exe)
Uptime:0 Day(s), 0 Hour(s), 00 Min(s), and 26 Sec(s)
File information:020421-10093-01.dmp (Feb 4 2021 - 18:07:42)
Uptime:0 Day(s), 0 Hour(s), 02 Min(s), and 24 Sec(s)
This information can be used by others to help you. Someone else will post with more information. Please wait for additional answers. Good luck.
So the non paged area is ram, its the area of ram drivers live in. Files that are paged are moved onto the hdd and drivers have to be in ram to work. Something told the kernel to move files out of the wrong location. That something being a driver but I can't tell what one. i shouldn't overlook another half of the story (I tend to get tunnel vision)
specs
mb - MPG X570 GAMING EDGE WIFI
CPU R7 3800X
Ram - 16gb CMK16GX4M2D3600C18
Storage - 1.5TB NVMe WD black
GPU - EVGA GTX 1070
PSU - Thermaltake 850 gold+
Try running memtest86 on each of your ram sticks, one stick at a time, up to 4 passes. Only error count you want is 0, any higher could be cause of the BSOD. Remove/replace ram sticks with errors. Memtest is created as a bootable USB so that you don’t need windows to run it
NVME - https://support.wdc.com/downloads.aspx?p=279
specs
CPU R7 3800X
GPU - EVGA GTX 1070
p=sharing
I know it's not the RAM. I have 2 different sets for a total of 4 modules, I've run each in each slot for 8 passes. Now, this wasn't yesterday obviously but it was while this whole thing has been happening. I will try the drivers for the NVMe for sure.
I've had additional dumps, I've uploaded them to the same drive as before.
https://drive.google.com/drive/folders/1-SgbWxS5rbNcn_YJLWJMFTZNMIF4GLCd?us
Please upload only new dump files to a new folder each time. Otherwise I have to go back and read the previous posts and try to determine which ones I've looked at, and which ones I haven't. Thank you.
I ran the dump files through the debugger and got the following information: https://jsfiddle.net/kx1me2pL/show This link is for anyone wanting to help. You do not have to view it. It is safe to "run the fiddle" as the page asks.
File information:020421-4703-01.dmp (Feb 4 2021 - 21:37:25)
Bugcheck:IRQL_NOT_LESS_OR_EQUAL (A)
Probably caused by:memory_corruption (Process: System)
Uptime:0 Day(s), 0 Hour(s), 33 Min(s), and 00 Sec(s)
File information:020421-4625-01.dmp (Feb 5 2021 - 00:01:52)
Uptime:0 Day(s), 2 Hour(s), 20 Min(s), and 37 Sec(s)
File information:020421-4578-01.dmp (Feb 4 2021 - 20:38:28)
Uptime:0 Day(s), 0 Hour(s), 56 Min(s), and 59 Sec(s)
File information:020421-4578-02.dmp (Feb 4 2021 - 21:03:55)
Uptime:0 Day(s), 0 Hour(s), 08 Min(s), and 37 Sec(s)
Ah sorry about that. Will do.
I am on my phone so I won't try to read the output file right now.
I wasn't sure about ram but if you sure about it I won't push it.
That's only because that was my first thing to try, I tested every module and then when that didn't work I installed Ubuntu and stress tested it there for several days to make sure it wasn't hardware.
sick of seeing page faults in explorer, its about only thing thats been consistent across the last 3 pages.
explorer runs task manager and file explorer
BIOS 1.D is out, it might help
https://www.msi.com/Motherboard/support/MPG-X570-GAMING-EDGE-WIFI
1st crash looks like windows trying to talk to CPU but it didn't go as planned
2nd crash looks like 1st one
these 2 might be helped by a BIOS update.
last 2 make me wish i understood windows better. I can't tell what PC was trying to do at time.
Ill give the bios a shot, and man you're telling me. I wish I understood too, hahahaha.
I ran the dump files through the debugger and got the following information: https://jsfiddle.net/o0c2dzu7/show This link is for anyone wanting to help. You do not have to view it. It is safe to "run the fiddle" as the page asks.
File information:020521-3562-01.dmp (Feb 5 2021 - 21:18:36)
Bugcheck:DRIVER_VERIFIER_DETECTED_VIOLATION (C4)
Uptime:0 Day(s), 0 Hour(s), 00 Min(s), and 09 Sec(s)
Driver verifer didn't mention driver name (again) but it left clues (again). No drivers but i know some of the windows drivers that were running just before it crashed.
wdiwifi - wdi driver framework (although it doesn't spell it out anywhere, indications are the last 4 letters do in fact stand for WIFI (this is part of windows)
ndis - Network Driver Interface Specification
Sep 16 2020Netwtw04.sysIntel Wireless Wifi Link driver https://downloadcenter.intel.com/
there should be newer versions of these drivers on the Intel website, I have Version 19.51.31.1 which if I search it is dated this month.
i can't tell you much about 2nd one.
Is there a different type of DMP yall would prefer?
