[SOLVED] be quiet dark power pro 11 850w vs corsair rm850i
adrifoxbg
114
13
4,585
In Bulgaria, traders claim that be quiet has classes above the corsair.
I really dug in quite detail, and saw that the corsair has a much higher voltage. Not so much but it costs less and has a 10 year warranty.
be quiet is effective up to 92% corsair 90% gold vs platinum
In the end, what is decisive? Efficiency or power?
Does it be quiet more as a quality and choice, or corsair remains a good choice as a warranty, powerful ?
Thank you
exactly. my bad experience with cx850m makes me think.
The cxm and Rmi can't be compared. The RMi is so much better. As I mentioned before, the rmi tests better in regards to load regulation, ripple, transient loads, etc. It is by all means the better unit outside of efficiency.
Not to say the be quiet is bad, it's certainly good. Just giving you the info. If the be quiet is more easily serviced in bulgaria then the corsair, and that's what's more important, you have your answer.
Otherwise, my vote is for the corsair.
adrifoxbg
114
13
4,585
I actually changed my mind.
I don't need 1000 watts
that's why I chose be quiet dark power 11 750w
I think it's enough for me to even put core i9 10 generation and rtx 2080, the calculator of be quiet requires me about 600 / 650 watts
