Question Be Quiet Light Wings aRGB aren't being detected.
I recently purchased "be quiet Light Wings aRGB 120mm triple pack" and they work and light up in the default rainbow sequence, however the issue im having is that Mystic Light nor SignalRGB are able to detect them and im not able to change the colour.
Does anyone know the reason or a solution for this?
Motherboard : MSI B650 Tomahawk
Which header are you tethered to on the motherboard?
BIOS version for your motherboard? Use one app. Uninstall Dragon Center, reboot then manually reinstall with the latest version. Go back into Dragon Center, using Mystic Light app, see if you're able to get ARGB functionality.
Thank You 😀
i've used the JRAINBOW header on the motherboard.
The BIOS version im currently running is 7D75v1E5
I'll try to uninstall and reinstall the Dragon Center and should i uninstall SignalRGB?
TWO Things to do.
1. As Lutfij said above, use only one software tool. UNinstall SignalRGB, and use only Mystic Light within the Dragon Centre for this, if at all possible.
2. You are using the correct JRAINBOW header. However, I see it is the new Gen2 variety. That recently-introduced system only works IF your LIGHTS also are Gen2, and the ones in your fans are not. BUT there's and EASY FIX. Because this design is new, all such systems have an option to configure them to work the old original way, instead of Gen2. I expect yours was set to the Gen2 mode by default. Look in Mystic Light for an option to switch this feature from Gen2 to Original.
TWO Things to do.
Thank youuu!
that solved my issue. changing from Gen2 to Orignal. <3
