Creative solutions for quiet cooling
be quiet! Teases New AIO With Double-Decoupled Pump : Read more
its not connected directly to either end of cooling loop so you can replace or expand either end I suppose.Perhaps a dumb question, but if the pumps are inline, from what exactly are they decoupled?
Makes sense, thanks. I suppose the USPTO once again missed the "non-obvious" requirement for awarding a patent.It mostly refers to the fact its not attached directly to the CPU cooling plate or directly to the radiator...Attaching it directly to the CPU cooling plate is not allowed because Asetek holds a patent for that.
Double-Decoupled
Ugly design and not practical that pump should be part of the radiator ...
By putting the pump in line they decouple the vibration from either the coldplate/motherboard and the radiator to reduce the vibration potentially transferred to the case.
.... Attaching it directly to the CPU cooling plate is not allowed because Asetek holds a patent for that.
.... The main issue with AIO is that the channels are way too narrow.
Well, they had no choice. Because of Asetek's patents. So they can't put the pump together with the waterblock (till the patent expire).
