Hi,
so when I started my PC today, there was suddenly a problem where it beeped once long and 3 times short and there was no display on the monitor ("No DVI Signal"). My PC has worked fine till yesterday. I do remember getting one or two BSODs in the past though that said "Memory_Management". What eventually resolved the beep issue was me taking the CMOS battery out and putting it back in.
But the monitor still displays nothing when the DVI cable is connected to the graphics card. The graphics card fans are running. I tried HDMI cable, that didn't work either.
It works if I connect the monitor to the motherboard. Which is weird because in the BIOS settings, I have the PCI slot for the graphics card selected and the graphics card is inside the PC.
Is the issue a faulty graphics card?
Thanks for any help.
Monitor: ASUS VG248QE
Motherboard: Gigabyte GA-Z87X-UD3H
GPU: Zotac Geforce GTX 780ti
PC is 4 1/2 years old, used almost daily, mostly for gaming.
(Sorry for my bad English, I'm not a native speaker)
P.S.: Another thing I did was changing around the 2 RAM sticks. All combos basically, one left, one right etc.
