BenQ XL2411Z 120HZ instead 144HZ on 4:3 1024x768 in CS:GO.. When set 144hz 1024x768 on CRU.. monitor writes "out of range"
Petr_1
12
Hello i got new monitor BenQ xl2411z.. The issue is that i want to play csgo in 4:3 1024x768 in 144hz but i still have only 120hz. when i downloaded CRU i configured 1024x768 to 144hz and started CSGO... monitor writes "Out of range"(only at fullscreen). And I have DVI-D cable, MSI r9 270x(radeon). I know its not big difference between 144 and 120hz but i just want to know why i cant run it at 144hz ..if its only bug or i cant just do it 😀 but i see some csgo pro players normally have this monitor, same resolution and they play with 144hz. Sry for bad english 😉 Some tips how to fix it or something what i can do with that ? :)
I didnt set anything at cru before.. i just downloaded it because i had csgo in 120 when i start it without cru :) https://ctrlv.cz/p6PZ This is my CRU now. I tried to change the 1024x768 to 144hz but everything in standard resolution i cant change to 144. But i have alrdy there in detailed resolutions on full HD in 144hz but when i set that 1024x768 to 144hz. And get that resolution in windows or csgo it will still write out of range :)
Nice I did it and it worked but i had it with black bars :) Then i go to amd settings and set the fullscreen on every program on this monitor :) ty for help !! :)
