Benq XL2430T Headphones connection
jjpod
I just got a new Benq XL2430T monitor, I have a problem to connect my headphones directly to the monitor (on the left side) Indeed I'm connected by DVI-DL for video and HDMI for sound ... but it's impossible to get at the same time a video game at 1920 x 1080 @144Hz with sound in headphones ... I don't find a suitable solution ...thanks in advance for your help
Jjpod
http://www.manualmonitor.com/manuals/benq/BenQ_XL2430T.pdf
4. Connect the headset.
Connect the headphone connector of your headset
to the headphone jack found on the left side of the
monitor.
Connect the audio cable between the PC and the
monitor (via the Mic-In jack at the back). And then
connect your microphone connector on the
headset to the microphone jack at the left side of
the monitor.
The headphone jacks work only when the audio source is
HDMI or DisplayPort
so, for 144hz gaming + headphones, a Display Port cable purchase is required make sure you get a good one
http://www.displayport.org/cables/how-to-choose-a-displayport-cable-and-not-get-a-bad-one/
So do you know if i can use my mic also if I get a display port or does DP's only transmit sound and not voice
What Audio cable! Sorry if I sound stupid...Do I have to order one?
pc(mobo audio) to monitor (via the Mic-In jack at the back) please refer to monitor manual i have posted.it even has pictures!
wow, i've got the same monitor, and been wondering why mic jack is not working xd yeah.. why the hell they can't put audio cable into same box with monitor!!! 300GBP monitor, and they can't put worthless audio cable into box!!! 21st century...
