O oxidante Prominent Nov 26, 2017 2 0 510 Nov 26, 2017 #1 Hi, I am wondering beQuiet! Dark Rock Pro 3 will be fit to my case? Here are my needed specs; Case: Cooler Master CM690-III MBO: Gigabyte Z170X Gaming G1
Solution COLGeek Nov 26, 2017 Yes, these components will all fit and work together. The case will accommodate: "High-end component support – long graphics cards up to 423mm and tall CPU coolers up to 171mm" Source: http://www.coolermaster.com/case/mid-tower-cm690-series/cm693/
COLGeek Cybernaut Moderator Apr 6, 2009 54,996 3,665 179,340 Nov 26, 2017 Solution #2 Yes, these components will all fit and work together. The case will accommodate: "High-end component support – long graphics cards up to 423mm and tall CPU coolers up to 171mm" Source: http://www.coolermaster.com/case/mid-tower-cm690-series/cm693/ Upvote 1 Downvote Solution
O oxidante Prominent Nov 26, 2017 2 0 510 Nov 26, 2017 #3 COLGeek : Yes, these components will all fit and work together. The case will accommodate: "High-end component support – long graphics cards up to 423mm and tall CPU coolers up to 171mm" Source: http://www.coolermaster.com/case/mid-tower-cm690-series/cm693/ Oh perfect, thanks a lot! Upvote 0 Downvote
