Question Best 1440p 144hz display that has an optical port
Parv patel
48
I have the ps5 and astro a59 gen 3. I want to get a new monitor that is around 300. But I need an optical cable for my headset. I have an hdmi adapter right now but it only supports 60hz. If anyone know a good monitor with an optical port, vesa mountable, and either 2 hdmi ports or 1 display and 1 hdmi. That would be greatly appreciated. Also if you know of an hdmi audio adapter that supports 1440p and 144hz that would also be great
I wouldn’t be so confident. Even if they switch it on there is no guarantee it will be applied to all games. If they have not designed a game to run at 1440p 60fps or 120fps it will need an update developed.
Oh. Yeah I didn't think of that. Do you know any good 1080p or 4k displays with everything that I said in the original post?
I don’t know enough about all the models to really give a good answer. I doubt a good high Hz 4K is in budget. What I can say is I use RTings.com as a starting point for monitor reviews. If I am still interested after their review I will look for others. Well that’s what I did about a year ago with my monitor.
Ok. Do you know of any hdmi extractors that supports 1080 p at 144gz or 4k at 144hz? Because all the ones that I see only support 60 hz
Hey I'm just curious if you figured out your problem? I have the astro a50s and I have the same problem with the audio extractor
