Best 21+ LCD monitor for CAD\Games
kogo
13
I was about ready to order the CML174, but I seem to be in a new position that allows me to get something a bit better. I'm considering getting a Sony GDMF900W for home use, with the Hitachi as a lan display, but I'd rather go with a single solution that can meet all my needs. I'm primarly concerned with response time... I'm sure they all look nice, but do they ghost? It seems most 20+ inch LCDs have unlisted or slow (>25ms) response times. I've looked at the Viewsonic VP2290b\VP230mb, the Samsung 240u, and a 50 ms Sony 23 that seems a little too slow for consideration. Any suggestions or advice?
If you can afford it..... there is a 20.1" <A HREF="http://www.formac.com/p_bin/?cid=solutions_displays_gallery2010" target="_new">formac</A> . They supposedly guarantee that the color quality is as good as a CRT, and it has a DVI connector. As far as ghosting, you will have to buy one and make sure you can return it if you are not satisfied.
There is also the <A HREF="http://www.sharpsystems.com/tmplproduct_T2020.asp" target="_new">sharp</A> which is 20". It uses 10 bit gamma correction so it displays enough colors for proffesional work, and it has a 25ms response time which sounds pretty ok.
I would get both , and return whichever I didn't like :)
<P ID="edit"><FONT SIZE=-1><EM>Edited by NoTiG on 01/09/03 08:47 AM.</EM></FONT></P>
Latest posts
