Best aftermarket CPU cooler without a backplate.
Daniel Byun
60
I am looking for a new aftermarket cooler but my mobo (Asrock Fm2a88x-itx+) has a vrm on its back near the CPU socket which interferes with almost every after market CPU cooler which uses a backplate. I was wondering about the best CPU cooler that does not require a backplate.
My Case: NZXT Phantom 410
Thanks~
Yes, at stock speeds it's more than adequate. Motherboard CPU socket temps are 33° idle and 52-54° under load, AMD overdrive never dips below...
I cannot fully trust them as I have seen people with some of the same motherboards and some of those coolers. They all said because of the vrm they didn't end up installing it or had to cut out pieces of the backplate which I cannot currently do.
The only cooler that I know fits for sure is the Noctua NH-L9a because it comes with its spacers. But I find its performance quite bad compared to its price. My 2nd option is the Coolermaster Hyper TX3 Evo but I am not sure if it fits on the FM2+ platform.
+1 for the TX3, it installs using the same retaining clip as the stock cooler and fits the FM2+ platform (Source - installed one on a FM2 mobo a couple of weeks ago)
Hows the performance? Does it cool ok?
I think I might go with the CoolerMaster Hyper Tx3 Evo. Its cheap and it cools decently.
Yes, at stock speeds it's more than adequate. Motherboard CPU socket temps are 33° idle and 52-54° under load, AMD overdrive never dips below 30° under load. The hardest thing is getting an accurate reading, CPU package temps are still way off - like, 85° under load.
