[SOLVED] Best budget speaker for good quality sound for music on PC ?
hang-the-9
Not enough info to suggest anything, what is max amount you want to spend? "budget" can be $20 or $150 considering speakers can top 2-300 easily. Size? 2.1 with sub or just 2.0? Full size, compact? You can adjust bass and treble settings in more than just the speakers.
hang-the-9
