Best case for around $150 dollars and lower
44borna
115
Hi, I am planning to buy a computer soon and I would like it to have a Zotac GTX 1080 Amp Xtreme, the GPU is 12.80 inches in length and about 5.9 inches in height (325.12mm and 149.86mm), not only that but I was hooping to fit the NZXT x61 in the case and fit the
Asus Z170-A, I don't really mind the look of the case as along as it has a side panel and has enough room for the components I am going to buy. My budget for the case was a maximum of $150 (CAD) but I was hoping for no more than $130, any help would be greatly appreciated.
For most non full size cases, you'll need to remove a drive tray for that video card, but that shouldn't be too much of an issue.
Off the top of my list of cases
http://ca.pcpartpicker.com/product/68YWGX/thermaltake-case-ca1e100m1wn00
http://ca.pcpartpicker.com/product/MsX2FT/thermaltake-case-ca1e300m1nn00
http://www.newegg.ca/Product/Product.aspx?Item=9SIA9H53XY9825&cm_re=H440-_-11-146-217-_-Product (Not sure why partpicker doesn't have an entry for this one)
http://ca.pcpartpicker.com/product/sjX2FT/fractal-design-case-fdcadefr5bk
http://ca.pcpartpicker.com/product/VK4NnQ/cooler-master-case-mcx0005kkn00
http://ca.pcpartpicker.com/product/vVwqqs/phanteks-case-phes515pabk
