Best case for the bucks and airflow?
beesmoko
43
i have several choices of case here
Cougar MG110-W
Corsair Carbide 88R
Thermaltake Versa H18
CoolerMaster N200
which one looks the best and which has the best reputation of each brand?
Pure airflow here would probably go to the Thermaltake Versa. Decent mounts for fans. Assuming you buy additional fans or use a radiator.
Corsair would follow, since it looks like you can get away with a top mounted 240mm radiator.
Cooler master would be okay for a mid-range build, particularly one using a downdraft cooler (stock Intel or AMD) But it would be a dusty case requiring regular cleaning.
Not sure about the Cougar. They make some nice fans, but I doubt they ended up in that case.
All of them though you probably want to add at least one front intake fan for GPU cooling.
