Best cases for cooling under 150 dollars?
markok6699
20
Hello, so i'm looking for Middle tower case that can cool my system well for price range to 150 dollars max. I was thinking about getting the NZXT Noctis 450 but i want to make sure that it's really good and i should get it OR if i should get other one (if yes, then which one).
For that budget, you can choose just about any ATX mid tower. Most reputable cases at the upper levels have decent or better airflow. What's slightly more important is the case fans and what you do with them. What fans, how many fans, in what orientation, at what speeds, cooling what components.
For example, my fractal design define R5 has a silencing door on the front, so air is drawn from vents at the side of the door. I use the 2 stock 140mm fans for intake. Exhaust is the 2 stock fans on my nzxt Kraken X61. And that's it. Yet no matter what I do with my gtx970 and i7 3770k (4.6GHz) case temps never reach beyond 34°C, usually staying around 32°C. And the pc sits inside a cubby in my desk. I've got good airflow in a case that's...
For example, my fractal design define R5 has a silencing door on the front, so air is drawn from vents at the side of the door. I use the 2 stock 140mm fans for intake. Exhaust is the 2 stock fans on my nzxt Kraken X61. And that's it. Yet no matter what I do with my gtx970 and i7 3770k (4.6GHz) case temps never reach beyond 34°C, usually staying around 32°C. And the pc sits inside a cubby in my desk. I've got good airflow in a case that's decent, but generally considered pretty adequate. Because of the fans.
