Question Best cooling solution!
Wolfman1983
7
Hello folks, I am looing for the best cooling solution for my i9 13900KF. The current case I have got is a Fractal Design Torrent Mid Tower, so I am looking for the cooling to fit that case. Thank you in advanced for any suggestions and help.
Well I currently got a AIO like that, NZXT Kraken 360 but it will not fit in the Fractal Design Torrent case. No 360 AIO will fit in that case with the parts I got. As I also got a Asus Strix OC 4090 and Asus ROG Gaming Wifi-E motherboard.
According to the specs page, it should...
GPU max length: 461 mm total, 423 mm with front fan mounted
Most AIO radiators are 27-30mm thick, so it should still fit with the 358mm long Strix 4090.
Is this the Torrent COMPACT instead? Because both Torrent and Compact are stated as mid towers...
Reactions: Why_Me
No it is a standard torrent, and a 360 AIO will not fit either at the bottom and certainly not at the top as the case has a lip on it.
It should fit at the front though?
The only radiators that are even an option at the bottom are custom liquid and Alphacool AIOs(due to the viewing window).
Please post a picture of the inside, with the glass panel removed(to avoid reflections and glare).
You must use an image hosting site to post pics here.
The case is designed for air coolers.
The front 180mm intake fans will move a ton of air through an air cooler, but also over the motherboard vrm and gpu coolers.
The case allows 188mm air coolers and one such is displayed in the stock photos.
About the best large air cooler around is the noctua NH-D15.
If you have tall ram heat spreaders, the next best that will fit is the nh-D15s.
Actually, the 13900K does nicely with less than top end cooling.
In video form:
View: https://www.youtube.com/watch?v=dNFgswzTvyc
