[SOLVED] Best CPU cooler for a R5 3600 @ 4.2GHZ
On stock cooler with a 4.2ghz OC and running at 90 degrees Celcius, so definitely time for a change in CPU.
I have found 2 Coolers that I like the look of:
1.
https://www.scan.co.uk/products/dee...hydro-cpu-cooler-2x120mm-rgb-fans-inc-control
2.
https://www.overclockers.co.uk/scyt...hd5dQzOiZb4HOqBsdJIBzJgi7oXk62HxoCHxUQAvD_BwE
Which would you chose out of these 2 or would you recommend another ( ideally under £100)
Cheers 😀
Look for a comparison between the Deepcool Castle and the Corsair H100i. I think you'll find the Corsair is better.
1.
2.
Cheers 😀
