Hi, I'm trying to find the best cpu AIR cooler for my new computer as I replaced my 5+ year old pentium 4. I bought this i7-4770k bundle from tigerdirect. I don't want to use liquid cooler because of potential leakage and it's more expensive than air coolers. I planned to use this system for live streaming and for gaming.
Link to the bundle i bought:http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=8680903&RSort=3&csid=ITD&body=#CustomerReviewsBlock
Computer Spec:
Intel Core i7-4770K Processor 3.5Ghz
Asus Z87-A Socket 1150 Haswell Motherboard
Patriot Viper Xtreme 8GB Desktop Memory Module
Gigabyte Nvidia Geoforce GTX 550ti 1gb graphic card
Ultra LSP Series V2 550-Watt Power Supply (I have a spare 600w PSU as well if the 550w PSU is not sufficient enough. http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3255393&CatId=1483)
Cougar Steel Gamer Case with a 120mm fan
500gb maxtor HD
2tb seagate HD
In the future I probably plan to OverClock the i7-4770k. I read some post on this site stating that 4.4ghz is the safest OC for this cpu? I don't mind 4.4ghz OC, but if it possibly can go higher then that's great. I would just like to have the OPTION to go higher that's all.
I've done some research on this site and read many post from people with the same problem as I am. I see many people going back and forth with some of the air cooler they advised.
Thermaltake NiC C5 (CLP0608) 120mm Untouchable CPU Cooler
Noctua NH-D14 120mm & 140mm SSO CPU Cooler
Cooler Master Hyper 212 EVO - CPU Cooler with 120 mm PWM Fan
Phanteks PH-TC14PE
Most I see people advised to get are the NH-D14 and CM Hyper 212 EVO coolers.
All in all I would like to know:
-which one is better for cooling OC 4.4ghz or higher
-with all the other specs I listed for my computer
-good enough cooling power for streaming and gaming
-life span of the cooler.
Also would like to know if there are other air coolers better than the ones I listed out there that I don't know about. My price range will most likely be $30-60, but depending on the results I might go higher.
Thanks in advance
Computer Spec:
500gb maxtor HD
2tb seagate HD
Phanteks PH-TC14PE
Thanks in advance
