Best CPU Fan???
doglips
233
Getin ready to buy a AMD 3800 939 socket....what the best Heat sink/fan? Zalman???? ......Thermaltake????? And yes I'll be OCin...
The Thermaltake Big Typhoon and Zalman CNPS9500 are the best air-coolers out there, with the Big Typhoon being a bit better IMHO due to its huge 120mm fan.
All you got to do is move to a colder climate and use a stock cooler, its working for me, But thermal take has some really nice ones.
Something tells me that getting a new cooler would be cheaper and slightly less dificult than moving.
-mcg
-mcg
That something is called 'common sense'.
I live in Oregon.......And Im stayin...Not a Climate Issue..Lookin for Air coolin...Thanks
Agreed. The Arctic Cooling Freezer 64 performs nearly as good as Zalman's and Thermaltake's solutions yet costs much less. It is also AM2 compatible should you choose to go that route.
Now that serious suggestions have been made, it is now time for a satiracle comment. Tear the cooling fan out of a commercial air conditioner on top of a sky scraper and mount it to an enourmous copper heat sink strapped to the support beams of your house. That will cool your CPU..... Yeah.
OK....That's the best advise I've had sofar! But wait wasn't there a post on common sence up there someware??!!.....oh well...I'm goin for it!! :)
Thanks guy's......this should point me in the right direction!?!
The zalman cnps9500 is ok. I liked the 7700 better because it kept the video card and mem cooler. I would go with the thermaltake.
The Arctic Cooling Freezer 64 installs easily within a few minutes. No motherboard removal is necessary.
I have the freezer 4, and it's just a simple clamp on installation. It fits so tight, I thought I was going to break something though.
You're right, I was using one before my water cooling kit but I have replaced the fan with the Silverstone FM121 and makes it a whole lot better.
