[SOLVED] Best G-Sync compatible monitor with 260 euros?
ProPlayerGR
595
42
19,040
Hello everyone. I'm looking to buy a g-sync compatible monitor. My budget is around 200-260 euros(not more than that). I need the monitor to have 1080p resolution, 144hz and 1ms response time. Can someone recommend the best one with my budget? Thanks in advance.
Here's a monitor it's very close to the end of the budget but if you need something cheaper this monitor seems good.
The asus one. Is it good? Because when I was searching I thought that it's good but without seeing it in reality I can't be sure. Has anyone reviewed it? It's a bit out of my budget though, because I live in Greece and it costs about 300 euros. However I found an asus monitor that is good I think and it's inside my budget. I'm talking about the asus vg248qg. Do you think it's a good monitor?
