B barcelonaman Reputable Jun 25, 2014 12 0 4,510 Jun 25, 2014 #1 I need your help what would be the best graphics card for under 210$ the If its cheeper its better but i really wanna get the best bang for my buck. thanks for the help guys
Solution soullStream Jun 26, 2014 Depending on whether you go with ^^^ that, or a new card is up to you. But for the price range through most stores the 270x is the best bang for your buck. http://www.tomshardware.com/reviews/gaming-graphics-card-review,3107-4.html
TechyInAZ Titan Jun 23, 2014 18,246 421 81,340 www.youtube.com Jun 25, 2014 #2 r9 270X Upvote 0 Downvote
Francisco Costa Distinguished Nov 16, 2013 1,440 0 20,410 Jun 25, 2014 #3 http://pcpartpicker.com/part/msi-video-card-r9280gaming3g Upvote 0 Downvote
ksham Splendid Mar 29, 2013 8,398 1 29,960 Jun 25, 2014 #4 Sapphire Dual-X R9 270X ($174.99 after MIR + shipping) Upvote 0 Downvote
soullStream Distinguished Jan 4, 2012 152 0 18,710 Jun 25, 2014 #5 +1 for the r9 270x. Personally I would go the Asus Direct CUII as it has good cooling and is quiet. Upvote 0 Downvote
O OverclockAtlanta Reputable Jun 23, 2014 20 0 4,520 Jun 26, 2014 #6 I can get 760 it's better than r9 270x for that price Upvote 0 Downvote
O OverclockAtlanta Reputable Jun 23, 2014 20 0 4,520 Jun 26, 2014 #7 You will have to pm me because of forum rules but a local.Atlanta store sells.them.for cheap and r9 270 cost me around 147 up Upvote 0 Downvote
soullStream Distinguished Jan 4, 2012 152 0 18,710 Jun 26, 2014 Solution #8 Depending on whether you go with ^^^ that, or a new card is up to you. But for the price range through most stores the 270x is the best bang for your buck. http://www.tomshardware.com/reviews/gaming-graphics-card-review,3107-4.html Upvote 0 Downvote Solution
