best graphics card for me
Hello... Power WISE you getting One Great Video card there!!! We never had it so GOOD in the Old days. B )
Just make sure you keep your PS fans clean and have Good air Flow to it... HEAT KILLs anything Electronic.
ok last question this would work peftect with my psu? i read it only take 75w to run it
General
RAMDAC
400 MHz
Max Resolution
4096 x 2160
3D VISION Game Ready
Yes
Cooler
With Fan
Slot Width
Dual Slot
System Requirements
300 watt or greater power supply.
Dual-Link DVI Supported
Yes
Card Dimensions (L x H)
9.50" x 4.38"
Hello... if you want get down to calculating it for a "Perfect Fit" Look on your PS label for your +12 Vdc Current / amperage, What does your label say?
Your CPU/APU needs 65 watts 65/12= 5.5 amps of current. http://products.amd.com/pages/desktopapudetail.aspx?id=47&AspxAutoDetectCookieSupport=1
750 TI GPU needs 60 watts 60/12= 5 amps http://en.wikipedia.org/wiki/GeForce_700_series
You won't need a model with all those Fans On it... that may be the extra 15 watts or it is slightly Overclocked ?
Model Ac Bel HBA008-ZA1GT 350
Connectors 24-pin / 4-pin Power
2 x Molex
1 x Floppy
4 x SATA
Input 100-120V~8.0A, 50-60Hz
220-240V~4.0A, 50/60Hz
Output +12V1 - 13A, 12V2 - 13A
+5V - 10A, -12V2 - 0.3A
+3.3V - 10A, +5VSB - 2A
Peak Power 350W (Last for 30 second)
yes this is my powersupply
