[SOLVED] Best low cost 4 monitor setup?
netrate
157
I am looking for a graphics card that can handle four monitors. Presently I am using the Geforce GTX 750 ti.
Works ok with some small issues. I have had it for about 3 years now.
What are the issues? Are the issues why you are upgrading? What is the pc used for? Budget? Rest of specs to know what will work with your pc. Everything above a 750ti is going to do everything a 750ti can do and more. I suspect you don't want to downgrade.
