£100-130What's your budget so I can do my research on my sides
also forgot to mention that it has to be a Micro ATX mobo as my case only fits themHow much is that in $$$??
Understood, I'm partnered with ROG and will see what they come put with for you in your area............I gotchu!!also forgot to mention that it has to be a Micro ATX mobo as my case only fits them
nice one, cheers brotherUnderstood, I'm partnered with ROG and will see what they come put with for you in your area............I gotchu!!
Seeing as though you have convinced me into getting a ryzen 7 5800x3d instead would you still think the same?This what you need :
B550 VRM DB sheet
docs.google.com
Go for a mobo with at least a 10+ phase/vrm set up. Your 5900x needs a strong mobo to let perform best.
Yes, the 5800x3d will work with the higher end B550. I have an Asus B550 Prime Plus. Does great for my CPU OC. Very steady at 4.7ghz all core, and 4.85ghz on one or two cores.Seeing as though you have convinced me into getting a ryzen 7 5800x3d instead would you still think the same?
Would you consider the b550m-k decent?Yes, the 5800x3d will work with the higher end B550. I have an Asus B550 Prime Plus. Does great for my CPU OC. Very steady at 4.7ghz all core, and 4.85ghz on one or two cores.
I do admit to liking the MSI MAG Tomahawk. Any will work with your CPU. Just pick a decent one.
