C Curtis Baldwin Honorable Sep 14, 2013 84 0 10,630 Oct 4, 2013 #1 Hi i am building a pc and i am not going to be able to use a ethernet cable to connect to my internet so i have to use a wireless card what would be the best for gaming? thanks for any help
Solution rolli59 Oct 4, 2013 I can not find the std b/g/n but am presuming n, this is good for the price and speed presuming you are in the UK http://uk.pcpartpicker.com/part/edimax-wireless-network-card-ew7612pin Here are others if you like a specific brand http://uk.pcpartpicker.com/parts/wireless-network-card/#i=35&sort=a4 not that I think the brand matters but I have an Asus g adapter still working from 2003.
JOHNN93 Honorable Oct 3, 2013 1,030 0 11,960 Oct 4, 2013 #2 what distance are you going to be from the access point? Upvote 0 Downvote
C Curtis Baldwin Honorable Sep 14, 2013 84 0 10,630 Oct 4, 2013 #3 at least 10 m away Upvote 0 Downvote
JOHNN93 Honorable Oct 3, 2013 1,030 0 11,960 Oct 4, 2013 #4 http://www.tp-link.us/products/details/?categoryid=240&model=TL-WN881ND This model will do fine if you want a better solution and not worried is a usb port is occupied you can check these adapters http://www.alfa.com.tw/products_show.php?pc=34&ps=8 have the same model i used to not be able to access a network but with this i got 60 % in a basement what ever n type you choose and there is no wall or with one wall in the middle it will be fine Upvote 0 Downvote
JOHNN93 Honorable Oct 3, 2013 1,030 0 11,960 Oct 4, 2013 #5 http://www.newegg.com/Product/Product.aspx?Item=33-704-133&Tpk=N82E16833704133 this will suit you best Upvote 0 Downvote
C Curtis Baldwin Honorable Sep 14, 2013 84 0 10,630 Oct 4, 2013 #6 oh ok is usb better then or just the same? Upvote 0 Downvote
rolli59 Titan Oct 27, 2007 47,790 283 130,890 Oct 4, 2013 #7 I have 3 Rosewill n adapters and all work fine http://pcpartpicker.com/parts/wireless-network-card/#i=35&sort=a4&m=51 really which one to select is based on your router speed. Upvote 0 Downvote
JOHNN93 Honorable Oct 3, 2013 1,030 0 11,960 Oct 4, 2013 #8 it depends one will use a usb and one a pci express the alpha are used for long range but in you're case where you are 10 meters anything will do the alpha will be a over kill and it will produce radiation stick with this one http://www.newegg.com/Product/Product.aspx?Item=33-704-133&Tpk=N82E16833704133 Upvote 0 Downvote
C Curtis Baldwin Honorable Sep 14, 2013 84 0 10,630 Oct 4, 2013 #9 my download speed is around 10mbps and upload is 1 mbps what will be best Upvote 0 Downvote
rolli59 Titan Oct 27, 2007 47,790 283 130,890 Oct 4, 2013 #10 What is the make and model of the router? Upvote 0 Downvote
JOHNN93 Honorable Oct 3, 2013 1,030 0 11,960 Oct 4, 2013 #11 rolli59 : I have 3 Rosewill n adapters and all work fine http://pcpartpicker.com/parts/wireless-network-card/#i=35&sort=a4&m=51 really which one to select is based on your router speed. Curtis Baldwin : my download speed is around 10mbps and upload is 1 mbps what will be best go with the rosewill rolli56 suggested. The ones i suggested are for really special cases when exceeded over 30 meters Upvote 0 Downvote
C Curtis Baldwin Honorable Sep 14, 2013 84 0 10,630 Oct 4, 2013 #12 http://www.sky.com/shop/broadband-talk/sky-hub/ this is it. Upvote 0 Downvote
rolli59 Titan Oct 27, 2007 47,790 283 130,890 Oct 4, 2013 Solution #13 I can not find the std b/g/n but am presuming n, this is good for the price and speed presuming you are in the UK http://uk.pcpartpicker.com/part/edimax-wireless-network-card-ew7612pin Here are others if you like a specific brand http://uk.pcpartpicker.com/parts/wireless-network-card/#i=35&sort=a4 not that I think the brand matters but I have an Asus g adapter still working from 2003. Upvote 0 Downvote Solution
JOHNN93 Honorable Oct 3, 2013 1,030 0 11,960 Oct 4, 2013 #14 Curtis Baldwin : http://www.sky.com/shop/broadband-talk/sky-hub/ this is it. http://pcpartpicker.com/parts/wireless-network-card/#i=35&sort=a4&m=51 one of these will do fine as rolli59 suggested before Upvote 0 Downvote
C Curtis Baldwin Honorable Sep 14, 2013 84 0 10,630 Oct 4, 2013 #15 nope dosent bother me thanks for the help Upvote 0 Downvote
