Question Best power supply for my new future setup.
janesiako5
Commendable
Sep 24, 2022
52
Hey, im want to bought computer for like max 6500 pln (more than 1000 dollars)
my future setup i have:
amd ryzen 7 5800x3d
be quiet! pure loop 120mm
rtx 3060 12gb version
and motherboard is Gigabyte B550 AORUS ELITE AX v2
i wanna buy an corsair rx750x 750w 80 plus gold - that costs 699pln
did i need more watts or what for my setup
be quiet! Pure loop 120mm cooler is insufficient for a 5800x3d which is the hottest cpu in the range due to the 3d vcache. The corsair h115i is more commonly use with it.
Corsair rx 750 is fine for that quality and wattage wise - psu tier list you might find a corsair tx 650m in the shops also would be fine. 3060 isn't the most demanding card in the range.
You might want to check if your selection of case can fit a corsair h115i at 280mm.
I used a Hyper 212 Black with two fans for a while and it did the job fine,the cpu will just go to 90C and then sit there, it had a small penalty for the boost. Really getting under 90C you will have to get a 360/420 rad. That 90C sounds bad, but the cpu is kinda designed to be fine with it. And that temp is under reall stress like R23 in a loop or similar.
