Question Best settings Sapphire Nitro+ 7700xt (easiest way)?
Phil_33
272
20
18,695
Hi,
I wanted to ask what is what are the best settings I can get from the Hypr RX program?
Atm it's like this:
https://ibb.co/JBWRhsc
https://ibb.co/3F0SHtt
So my full system is:
CPU: R5 7600 no pbo
Motherboard: MSI B650 tomahawk wifi
Ram: Corsair Vengeance 32gb 6000mhz cl30
Storage: Kingston KC3000 1tb
GPU: Sapphire 7700xt Nitro+
PSU: Corsair 750w rmx
Case: Fractal Design Meshify 2
Display: LG 24 inch 1ms 1080p 144hz
I'm starting to have some difficulties, still running everything all wide open on ultra without any upscaling or FSR.
I have a hard time believing that the 7700xt cannot manage ultra settings for 1080p and at least well over 100-120 FPS (if not maxxed). I guess it would be a part of that to consider what games are being run.
I have a Sapphire 7800xt on an 11900K and still run everything on Ultra at 1440P and framerates for most of my games are North of 120FPS, and many just sit on 144. I have nothing turned on aside from Freesync Premium. I do avoid using Ray Tracing with it, as it absolutely tanks performance.
The one game that consistently beats my system up for its lunch money is still Cyberpunk 77. That console shows 68.1 FPS average for it. The next nearest in framerate is Division 2 @ 117.
if you disable Radeon image Sarpening it will be a little better, but you have to see the settings depending on what you play, for me it's fine anyway, try it
I have a hard time in believing this too but it happens with throne and liberty. The game should be way above, but instead, it's like 90 fps average and dips into 30 fps with cutscenes. Maybe not uptimised but then again, forza horizon 5 I expected more as well, but it runs the game at 90 fps, smoothly though...
That's why I asked if my options in the image are good?
With the Super Resolution turned on, I cannot change this. So which one is better? Super Resolution? Or Image Sharpening?
Depending on what you play, you also make the settings
At the moment I have enabled , Anti-Lag - Enhanced Sync - Surface format optimization in 6800
You change and test, there are benchmarks such as furmark that someone tests if want for example fps
My Sapphire Radeon RX 6700 XT 12GB GDDR6 Nitro+ (11306-01-20G) play all in ultra and this card is 7700xt not 6700xt
His card has many currents , 266 watts is not justified
also give a picture of GPU-Z with the bios wears
https://ibb.co/YkPFNg9
Let me guess.... For me to find out the issue that I got? Well just so you know, I don't know ANYTHING about this, I just bought the graphics card and plug in and play, and I discovered I had some tools to play with so I did...
I'm not in OC, and as you can see, no HYPR RX
And I sure as hell don't have the time to do the research... Maybe I should just let it in ECO mode and suck up the 30FPS
I'm trying to help you, there's something I don't like about your card and it has to do with currents
If you turn the switch from the card, how does it behave?
if I turn the switch then it would be in OC and I don't want that. Also take a look at this:
https://ibb.co/NSYnw3Q
https://ibb.co/P5nX8rn
My friend you have 266watt in you card ,you are high
I swear I did not touch anything. Just plug in and play and then yea the custom settings like you said and turn everything off except for these 3 options. The physicall button was on this profile where you can change it with trixx and I didn't touch a thing in trixx... And 1 tap to the right is profile 1 or silent mode and profile 2 is oc mode...
my friend, I didn't say that you messed something up,
I'm trying to help you and if you don't help, nothing can happen.
In the furmark you are below from my card at 1/3
