Question Best settings Sapphire Nitro+ 7700xt (easiest way)?
You didn't answer me here when I asked you earlier
1 cable splitter 2, 8 pin. Everything is correctly installed and updated. I'm not in OC and there's nothing that boosts the card atm. Hypr rx has a booster. Thats also somethings I wanted to ask, if I ever decide to use OC or the booster, how do I do this?
Put the second cable in your power supply friend, give power from it to the 2nd 8pin slot of your card, try it and come back to tell us what happened
don't say it again and again, your card is overclocked from the Sapphire
If you look into other people's score then you would come across this guy: https://www.gpumagick.com/scores/428616
Look at the powerdraw and the score. It would not be justified either according to you.
He has a 7800xt...
What I do think is that if I wanted more fps or have a higher score I would need to OC, simple as that.
Anyway, thank you for your time. Have a good one!
He has a 7800xt...
You put a second cable from the power supply to your card
But look at the score, friend, I honestly don't know what you want, you see a furmark with (VK)
The first score that I had was Furmark Knot, not Furmark Donut which is way lower score because it's a higher test...
As you can see here the score is way higher because I let it test with the furmark VK.
https://ibb.co/Fgtd6KP
Just as I thought, nothing wrong and I don't need to change anything. Your score is higher because you OC'ed your card obviously and you tested in Donut, not in "Knot".
I told you something and you keep doing the same thing.If I was overclocking, you wouldn't see me at all from the score the card would give.
The card is in the photo I show you and it is from the factory without me tampering with it (which I don't need to do because I have another computer with a bigger one).
So stop talking about overclocking
You started to say why I have such a high watt and such a low score?
And you didn't see that I was testing in "knot"...
So anyway, bye!
