Better Upgrade: 980Ti Card or 27"qHD GSync Monitor?
rabaker07
51
Which would you suggest as a better upgrade, monitor or card?
I currently have:
EVGA GTX 970 SC
BenQ 24" 1920x1200 TN panel monitor
I want to upgrade by getting:
GTX 980 Ti
or
27" Gsync Monitor with 144hz at 2560x1440 pixel resolution - Acer XB270HU or ASUS ROG PG278Q
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487141
or
http://www.amazon.com/Acer-XB270HU-bprz-27-inch-Widescreen/dp/B00UPVXDA8
http://www.amazon.com/PG278Q-27-Inch-Screen-LED-Lit-Monitor
And if the monitor is the way to go, do I wait for the new ASUS IPS? Or will that end up costing $1000+? I'm currently leaning toward either the ASUS or the Acer 27 inch 144hz Gsyncs.
And will I find that with the new monitor, that the GTX 970 won't have quite the horsepower to drive the higher resolution at high/ultra settings and still maintain 60+ frames per second? Vsync is very very very important to me and I will always take lower graphics settings rather than sacrifice anything under solid 60fps. This makes animation look fluid and gives it that real 3d-ish feel.
**** So which is it? The monitor (and which one), or the new card? ****
A12MO12
202
33
in terms of performance a 980 Ti is roughly 45% ahead in performance. Another option could be SLI 970s which is around 5-15% better performance than 980 Ti.
I would suggest this monitor- The ROG swift 1440p 144hz monitor, same price as the other one. http://www.amazon.com/PG278Q-27-Inch-Screen-LED-Lit-Monitor/dp/B00MSOND8C/ref=sr_1_2?s=electronics&ie=UTF8&qid=1437074260&sr=1-2&keywords=1440p+g-sync+monitor.
The most sensible thing to do would be to get another 970 for SLI then save up for the ASUS ROG 1440p monitor.
rabaker07
51
And why the ASUS ROG over the Acer? (I'm torn between the two).
I like what the others have said about getting the monitor first, and saving up for the next GPU solution, whether that be SLI 970s or 980Ti). I'd prefer a single-gpu in general, but if I can get 15% better than the 980Ti for $300, that may be the ticket. Only problem is, my MoBo has only 2x8 pci-e slots (when in SLI mode) so I'll prob have to buy new mobo and might as well get a better proc while I'm at it... I have i5 3570k OCd to 4.3.
See what you did?!
A12MO12
202
33
Just seen the ROG recommended more its up to you if you want acer one or stick with ROG. Yeah these things get expensive when you want to upgrade ha
Jonathan Cave
1,426
115
I would buy the Acer Predator XB270HA 27" G-Sync 144Hz Gaming over the ROG Swift , the Swift is too expensive.
I sold my 2 x 970's and Bought a 980 Ti and instead of getting a 1440p 144hz gsycn pannel i got a 60hz gsync 4k pannel.
A12MO12
202
33
a the Acer Predator XB270HA is 1080p 144 hz monitor though, he is asking for improvement in quality. SLI 970s or 980 Ti would be a waste with that monitor.
Jonathan Cave
1,426
115
Oh i'm sorry i got muddled up.
There's only 2 contenders in the gsync market @ 1440p which is the Acer Predator or the ROG Swift (as you have been discussing)
In the coming months IPS versions of these pannes will come to market:
http://www.144hzmonitors.com/monitors/7-new-g-sync-monitors-soon-to-be-released-144hz-ips-asus-monitor-is-one-of-them/
Maybe hold off for one of these.
I had the same gysnc dilemma - 1440p @ 144hz or 4k @ 60hz - i went with 4k and i don't regret it one bit! Arma 3, DayZ and other games i play such as ARK look stunning in 4k. When i drop down to 1440p i get a mental distaste.
Similar threads
