Big trouble.... need help
kallu_urmachan
4
hi guys..
need some serious help....
i`ve got randomly selected for my class project....
topic: IMPROVISE CPU WATER COOLING SYSTEMS
i dont even kno what it means....
gimme some help an article which i can submit....
i`m counting on u guys(whom ever it might be) pls... my grade depend on this......
pls save my asssssss......
send ur emails to
kalyan2s2@gmail.com
improvise cpu water cooling system i believe is just a basic water cooling system. Only reason that improvise was used i believe is because the normal means of cooling computer's and for the most part the CPU is with fans so just talk about how a WC System works to dispel the heat generated by the cpu
Are u online???
can we chat??
hi...
i kno i make myself a lame dodo to doing dis... no way out......
pls pls pls... tell an area tat can be improvised or the improving the whole WC system lik any new product in the market....
i keep search but couldn`t find any thing abt this.....
sry for bothering u again.........
If you're expected to improvise, what are the limits you're expected to adhere to? IE Money, Parts that can be purchased, Etc.?
Complete cooling from scratch would require you to have access to machining tools to create the CPU cooling block?
http://www.webx.dk/oz2cpu/pcmod/water.htm
However if you're allowed to at least purchase a a premade CPU cooling block then its definitely doable!
Consisting of:
A cooler probably at least a 10 gal capacity with water in it
a 12v submersible boat bilge pump
old computer power supply and relay,[or use the computers power supply you'll be cooling getting the 12V supply for the water pump off a molex connector]
High Flow W/C CPU Heatsink, [Danger Den or comperable]
Clear polyvinyl tubing, hose clamps and a computer
You can add a cooling radiator, by either using a Transmission cooler, or heater core, automotive type
It all depends on how elaborate you want to go, and what your limitations are.
http://www.xtremesystems.org/forums/index.php? Not a noob site, but great stickies
http://www.ocforums.com/ My fav, good peeps, know their stuff, less hardcore
http://www.skinneelabs.com/MartinsLiquidLab/
http://www.over-clock.com/ivb/index.php?showtopic=20277 A GREAT Europe site
http://www.overclock.net/water-cooling/
http://translate.google.com/translate?u=http%3A%2F%2Fwww.effizienzgurus.de%2Fmain%2Findex.php%3Fcontent%3Darticle%26action%3Dview_spec_article%26article_id%3D222&langpair=de%7Cen&hl=en&ie=UTF-8 Info on rad testing
http://skinneelabs.com/
