G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
My desktop PC runs fully updated XP Home SP2.
Recently the CD-ROM drive has started disappearing
and reappearing for no apparent reason and now it
seems to have vanished for good. When visible the
drive operates normally but in invisible mode it
not only disappears from My Computer and Device
Manager but BIOS Set-up reports the IDE Secondary
Master as "None". If I then select Detect Hard
Drive the drive name is usually reported as a
string of garbage characters, though on one
occasion the drive was correctly identified.
Unfortunately the latter spasm of visibility
failed to survive the subsequent boot.
I assume from all this that I probably have a
hardware problem and that my next step should be
to replace the drive. However I'd be grateful if
anyone has any useful comments or alternative
interpretations, or can suggest other diagnostic
or remedial procedures which I could try?
Thanks in advance.
Thanks in advance.
