Bios, mobo, psu problems? help please
goat199
42
Ok so i just got my motherboard back and I am having problems again. my last mobo quit loading up. So now I am having the following problems randomly:
Blue screen once a dayish randomly.
somewhere in cpu-fan is making a noise.
Im monitoring the mobo and cpu. cpu gets to 45c and mobo does too.
sometimes bios wont load and i cant start windows so i have to wait a while
sometimes bios loads then right after loads again and goes into an infinite loop.
So im thinking the mobo either has a defect or the PSU isn't enough power (520w). Here is my system specs:
4GB 800 DDR2 SDram
AMD Phenom™ 9600 Quad-Core Processor
NVIDIA Nforce 750a SLI Motherboard
Geforce GTX 260 graphics card
HX520W corsair PSU
Vista 64
ASUS nforce 750a M3N72-d
I did memtest86 for 18 hrs. NO errors. I have 6 fans in my case, only 3 of them are on. When I add another, windows won't load, sometimes the bios wont even load. So I am sticking with 3 for now. So im confused...
What is the exact model of your RAM? We need a little more than "4GB 800 DDR2 SDram ".
The 520HX is a nice PSU, but it's cutting it pretty close with a GTX 260. If your system really becomes unstable when you add a fan, you might be running at the limits of your PSU. I currently run the 520HX in my computer and love it, but I'd never think of trying to power a GTX 260 with it.
ok so I have eliminated ram and the CPU, and there is a good chance it is the PSU. but i just got my mobo back from asus and i'm sure it is refurbished. so Any thoughts?
Do a little math on the wattage that ur components are consuming, there's a probability that u are exceeding the wattage that ur PSU can handle.
(forgot where i saw this wattage calculation)
Motherboard: 15W-30W (if it's a high-end mobo, better to assume that it's using 25-30W)
Mid-High End CPU : 40W-100W (AMD PQ4 9600 is 95W)
RAM: 7W/128MB (in ur case 4GB or 4096MB will consume 224W)
High-End GPU: 60W-100W (but in ur case GTX 260 is consuming 185W at maximum)
IDE Hard Drive: 10W-30W (per IDE hdd)
Optical HDD: 10W-25W (per Optical hdd)
with that just above u are already consuming from 569W-589W assuming that u have only 1 IDE hard drive and 1 Optical Hard drive. Also every PCI add-in card will also add 5W.
